This command configures a router to reject SA request messages from a specified peer or all peers.
| peer all | Specifies all MSDP peers. |
| remoteaddr | Specifies the IP address of the MSDP peer. |
| vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
By default, all SA request messages are accepted from all peers.
Use this command to configure the router to reject SA request messages from a specified peer or all peers.
You cannot change an SA request filter while SA request processing is enabled for an MSDP peer. You must first disable SA request processing for a peer and then re-enable it with an SA request filter.
The following example disables processing of SA request messages received from a peer with the IP address 192.168.45.43:
disable msdp peer 192.168.45.43 process-sa-request
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
